where is the bearing carrier for polaris hawkeye??
Old Mar 7, 2011 | 05:52 PM
Wozy's Avatar
Default where is the bearing carrier for polaris hawkeye??
i cant find the bearing carrier for my polaris hawkeye
Old Mar 9, 2011 | 04:41 PM
Lolumad273's Avatar
Assuming you have the 2006 model, since I'm not sure if it's different on the 2007 model. If you look at the Rear A-arms, they're on the end where the wheel connects to the A arm. If you look just below the bottom A arm, there's a little grease fitting on it. It's pretty difficult to spot it, but that should indicate that you've found the bearing carrier.
EDIT
I can take a picture of it soon
Old Mar 9, 2011 | 05:26 PM
Lolumad273's Avatar
Believe that's the bearing carrier, someone correct me if I'm wrong.
Old Jun 21, 2011 | 04:59 PM
ATV Connection Reporter's Avatar
Your question has been selected by the editors for our Ask the Editor column!
Originally Posted by atvconnection
Depending on the year in question, most Hawkeyes came equipped with sealed bearing carriers that do not contain external zerk fittings for purpose of applying grease.
To read the rest of the response, click here!
Thank you for submitting your question.
Ean
Dec 19, 2022 08:48 AM
mudpig79
Jul 13, 2015 03:31 PM
clsharky
Jul 13, 2015 02:07 PM
Shifts
14
Jul 13, 2015 08:41 AM
