First service checklist
Old Mar 11, 2011 | 08:40 PM
cyberhedz's Avatar
Default First service checklist
hey guys, so I finally hit my first 10 hours, planning on doing some preventative maintenance now. I wanted to know from those with wisdom, what i should check, replace, etc, at the 10 hour mark, and then i assume every 50 after that. I know that the owners manual has a list, but that same manual tells me that my bike will not work properly if water touches the footwells or if I try to climb a hill over 25*. So here is my list, which I will update as I become more informed.
First 10:
Oil and oil filter change
check airbox
check ADC fluid
check EPS fluid
check coolant
check tire pressure
Every 50:
oil and oil filter change
air filter change/clean
Old Mar 11, 2011 | 11:42 PM
switzomatic's Avatar
With the exception of coolant and brake fluid I change all other fluids when doing break-in service. Also, give the whole thing a once over for leaks, wheel bearings, tierods, play, etc.
Old Mar 12, 2011 | 06:43 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
What he said. After that I'd change all fluids every 50.
Old Mar 12, 2011 | 07:41 AM
Kerbbirds's Avatar
check front and rear ends, tranny, my rear end was low, I checked everythig at about 5 hrs, glad I did, I probably saved the rear diff cause it had very little fluid in it, dealer knows about it and its documented
Old Mar 12, 2011 | 09:36 AM
cyberhedz's Avatar
OK, edited to this:
First 10:
check airbox
change ADC fluid
change EPS fluid
check coolant
check brake fluid
check front & rear differentials
check tire pressure
check wheel bearings
check tierods
Every 50:
change ADC fluid
change EPS fluid
change coolant
change brake fluid
change front & rear differentials
check tire pressure
regrease wheel bearings
regrease tierods
as far as the grease to use, any personal recommendations? I plan using amsoil for the engine, popo oil filter, K&N air filter
Old Mar 12, 2011 | 10:47 AM
cyberhedz's Avatar
I have attached an excel spreadsheet, what do you guys think. I tried to trace down AMSOIL equivalents for everything possible, but from my research, the drive fluid should stay popo. Let me know what you think please.
Old Mar 12, 2011 | 03:36 PM
Looks good but my preference is all popo fluids. Doesn't really cost much more, makes for convenient one stop shopping, and is a security blanket with the dealer because they will know I am maintaining it regularly. Makes a huge difference if you ever have to bring it in for any warranty issues.
Old Mar 12, 2011 | 10:49 PM
cyberhedz's Avatar
understandable point, however my "dealer" is actually a john deer dealer, who happens to carry popo atv and utv's, so they don't stock any popo fluids or accessories. So if I have to order, i put my faith in amsoil.
Old Mar 13, 2011 | 09:54 AM
cyberhedz's Avatar
Can anyone double check my list of fluids, did I find adequate matches?
Old Mar 13, 2011 | 10:45 AM
Specta's Avatar
It's sad they sell them but don't support them. I think that is Polais' fault.
