warning lights??
Old Mar 12, 2011 | 07:00 PM
bigcam400's Avatar
Default warning lights??
'95 xplorer 400 4x4,..how can i tell if warning lights working?? only one ive seen come on is the reverse light,...its got a high beam indicator but it don't work,...its got a oil light but didn't think a 2 stroke held oil??? an water temp light ant ever seen it flash or nothing want to get all this workin right an maybe put a water temp gauge on it too,..thanks for any help!!
Old Mar 12, 2011 | 07:10 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Oil injector
Does that have the oil tank with the injector or do you have to maix your own gas before you put it in? I know the 300s have the injector that does the mixing for you! If this is the case, that may be your oil light!
Mudslinger2
Old Mar 12, 2011 | 07:18 PM
bigcam400's Avatar
yes its got the oil tank an all,..its full,..an seems to be working...it runs good,..got a few eletrical issues im workin on,..had to replace all the lights an i replaced the volt regulator,..hopin to get the starter right an make sure everything else is right like warning lights an cooling fan,...really would like a temp gauge!!
Old Mar 12, 2011 | 07:54 PM
Kerbbirds's Avatar
If all light bulbs were burnt out Ill bet someone ran it without a battery, that fries all the bulbs and probably the regulator too, battery act as a buffer, the oil light ect probably got fried too, take the [pod apart and look at all bulbs, renvrse , nuetral ect
Old Mar 12, 2011 | 08:21 PM
bigcam400's Avatar
he did keep sayin brand new battery,..only light bulb on it that worked is reverse...ill get that pod apart soon as i get radiator out cleaned an back in!!
Old Mar 13, 2011 | 04:35 AM
twister500's Avatar
Two stroke - Radiator?
Old Mar 13, 2011 | 07:21 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes it should be a liquid 2 stroke 400 for that year. i agree w/ kerbbirds in maybe he did run it a little w/ bad or missing battery.
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
