2007 Sportsman 500 Reverse Button Overide
Been awhile sense being here so this has probably been discussed. Is there a reverse overide switch that will work on the 2007 Sportsman 500 and where can I find it. Also does it interfear with any of the reverse button functions. I can't handle pushing that button anymore when the machine is really hung up.
Thanks for any responses.
You can put a toggle switch in. Splice one side into the grey/orange wire(If I remember correctly???) coming off of the over ride button and the other into the ground of your power outlet. With the toggle switch in the on position it'll fool the bike into thinking your holding the button. To scroll through your functions turn off the switch. Or go here for a kit. ATV Tires Wheels Aftermarket Parts ATV Quad Winch Exhaust ATVs UTVs Just to be sure can anyone verify the wire color coming off the button???
No problem. To double check I went through my electrical schematics and the gray wire with orange stripe is the correct wire to splice for your bike.
KimSJoh
14
Jul 18, 2015 07:20 PM
