Here is the updated PCV on 850 XP's
Old Mar 21, 2011 | 04:55 PM
awsume800efi's Avatar
Default Here is the updated PCV on 850 XP's
well here is a pic of the updated pcv for the 850 XP looks like the slots will allow water to drain back in instead of pooling and freezing the rubber that sits inside or maybe even releases pressure back in hope it works, note the moisture in the old one on the right the new style is on the left
Attached Thumbnails Here is the updated PCV on 850 XP's-droid-x-march-21-2011-033.jpg   Here is the updated PCV on 850 XP's-droid-x-march-21-2011-034.jpg
Old Mar 21, 2011 | 07:23 PM
850 trailrider's Avatar
Default 850 pcv
great picts ,does it look like we could heat up steel rod and melt notches at same locations or grind with dremel tool ?does the construction look much different looks like we could modify existing one fairly easily or do you think we need to get an updated one just wondering anybody else think???
Old Mar 21, 2011 | 07:36 PM
HaydenS's Avatar
What years have this problem? I have a 07 800 EFI
Old Mar 21, 2011 | 08:05 PM
for 18 bucks i would just put the new one in i think the center is depressed in a little more too
Old Mar 21, 2011 | 08:06 PM
only the 850 XP'S are affected your 800 is fine
Old Mar 21, 2011 | 08:26 PM
18 bucks ill just buy it, not worth the time and agrivation, just for piece of mind hope this finally fixes it
Old Mar 21, 2011 | 09:08 PM
i agree can only hope for the best but it looks to me like it will
Old Mar 21, 2011 | 10:18 PM
Wenty's Avatar
I thought they were a recall?? Why are they charging for them?
Wenty
Old Mar 21, 2011 | 11:44 PM
you are probably right about getting them free if you wanna wait i wasn't gonna wait till they were ready i wanted them now, one time is enough of that crap so i bit the bullet and bought them now and in my mind $17 isn't too bad for peace of mind
Old Mar 22, 2011 | 03:48 PM
Default new pcv update
same here went to dealer to check [he wasnt aware yet] and ordered mine back ordered 4 days from polaris just happy to know I got one coming heres my part#s check with your dealer to make sure
part#5438868 carriage-filter out[supercedes older updated one he says]
#5437432 felt breather
#5413445 o-ring
#5413446 o-ring
about 18 dollars + 2 new o rings
