backfire issue
Old Mar 21, 2011 | 09:41 PM
bodytech96's Avatar
Default backfire issue
when i ride my bike ay normal speeds i have no back fire issue. but when i get on the throttle pretty deep and and then let off my bike tends to back fire out nthe exhaust pipe. it seems to do itmore after it is hot. what might cause this it drives me nuts
Old Mar 21, 2011 | 11:43 PM
Usually this is lean condition when it backfires,the hotter it gets the leaner it runs and backfires even worse. Upping the main jet and possibly pilot jet and a little up on the slide needle will help, OR just a simple carb clean/rebuild if its a stock engine could help.(also check for intake boot leaks,cracks,or any thing that cause air leaks) Plus make sure fuel is fresh and air filter clean PLUS knowing what machine you have can help narrow down problems! OPT
Old Mar 22, 2011 | 04:59 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
running lean by the sounds. may want to check to make sure carb isn't dirty(most likely main jet side). if theres a fuel filter may rplace or at least check for fuel flow. imo
Old Mar 22, 2011 | 08:22 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
If it's only when you let off it is most likely NOT the main jet. If it back fired when you were deep in the throttle then that would be the main. When you let off the slow jet will take over.
Are there any mods? You can adjust the air/fuel mixture to adjust a bit. Turn a half turn at a time to see if it changes anything. If not you'll need to tear into the carb and clean it up. Something is prohibiting flow.
donintennessee
Jan 8, 2021 12:40 PM
COFatboy
May 2, 2020 12:06 AM
donintennessee
Aug 19, 2015 02:22 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
