KFX 450R chain????
Old Mar 22, 2011 | 03:27 PM
Dirtjunkie85's Avatar
Default KFX 450R chain????
Hey guys do you run a O-ring chain standard or X-ring and why?? It's time to replace mine and was wondering what you all use thanks!!
Old Mar 22, 2011 | 05:48 PM
Scooter86's Avatar
Knows Old ATV Questions!
X rings tend to hold lube in/dirt out a bit better than o-rings. Either one will give you good life if properly maintained and tensioned. Don't forget to replace both sprockets same time as the chain. Worn sprockets cause premature chain wear. For what it is worth, I have had real good luck with the Primary Drive sets. Good bang for the buck, although I replace the whole set every year regardless of condition.
Old Mar 23, 2011 | 09:57 AM
Hayashi's Avatar
Make sure you do double torque check on the chain adjuster bolts which tend to become loosen easily. When the chain comes off while riding, it can crack the crankcase.
Old Mar 29, 2011 | 03:45 PM
Thanks for the info guys I think I will go with the Xring once I figure out what is up with my motor thanks.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
