Polaris sportsman 700 Exhaust leak
Hey new to the site still figuring out how it works
Anyways i just got a 2002 sportsman 700 twin and it is really loud appears to be leaking where headers go into the the exhaust pipe its held together by springs ect.. haven't gotten really into it yet but just want see if anyone one else experienced this problem before and how to fix it! Thanks
welcome to the forum. replace it w/ a 800 header pipe which has a bigger output for better air flow and i think they were replacing the air box lids for intake air as well which in turn gave a little better performance. you might try ebay or a dealer can order. imo
I used to have an 04 I had issues with the header cracking and if its running cherry I burnt out 2 donuts before I rejetted had no issues after that headers can be found cheap I found one used on ebay for $24 to the house.
There is a an exhust seal in between the manifold and the main exhaust pipe, they need to be replaced every once in a while. The springs are a bugger to get on and off, a pair of vice grips or a hook tools works well for getting them off. Once the seal is replaced and its time to put the springs back on try this .... find a solid place to hook one end of the spring and pull with a pair of vice grips to stretch it out. Place pennies in between the loops until the spring is stretched to the length needed to get both ends on the mounts. Once you have the spring on the mounts just pull the pennies out with pliers. Kinda Red Green but if you dont have the right tools it works !
bonanza 440
Jun 26, 2015 10:01 PM
May 27, 2015 11:15 AM
