06 sportsman 800 trouble
Old Apr 6, 2011 | 09:59 PM
jwalto74v's Avatar
Default 06 sportsman 800 trouble
i was wondering if anyone had any ideas on my 06 sportsman 800,ive been around polaris atvs for awhile and am mechanically inclined,but im a newb when it comes to efi, so machine was running great, but battery was getting bad,(cranking hard) then it sat a couple months,and battery died, so i jumped it with my truck, started right up,idles fine but if you try to ride it,and give it throttle it has no power, backfires and just runs like crap. i since put abrand new battery in but same problem.polaris dealer was no help. any help is greatly appreciated,thanks in advance.
Old Apr 6, 2011 | 10:14 PM
Could be bad fuel if sitting up for a while, I would change that,plus check air filter and plugs. If still have idle, popping back problems could be efi related. Check for codes on display. Check sensor wiring for chaffing,broken wires. Repair harness kits available for T-bap,Tps sensors,etc.. OPT
Old Apr 6, 2011 | 10:54 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
What OPT said. For the T-bap which seems to be a common problem on the 700 & 800 take a look at this link.http://forums.atvconnection.com/pola...ap-wiring.html
Old Apr 7, 2011 | 04:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does sound like electrical like the tbap harness. make sure the plug plug wire/plug is good and maybe put does dieletric grease in the cap. sometimes they break down and spark will be jumping through. imo
Old Apr 7, 2011 | 06:28 AM
jwalto74v's Avatar
thanks guys,i will check that tbap thing,oh i forgot to mention,this is very embarrassing,when i jump started it,i hooked the jumpers up backwards for a few seconds,first time i have ever done that! just days before that my neighbor did that on his truck,and i thought what a dumb ***,how could anybody do that? anyways hooked up backwards and possibly fried something? checked all fuses they are good. well guess ill start with the tbap,thanks again
Old Apr 7, 2011 | 12:05 PM
NOT GOOD! Try the repair kit. I would cross my fingers for you but RA won't let me! Good luck. OPT
Old Apr 7, 2011 | 06:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pray that you didn't do damage by reversing cables as a few have done it causing major electrical componant damage.
neo27ny
Aug 24, 2015 02:02 AM
toonces
Aug 21, 2015 01:19 PM
house1
Aug 9, 2015 10:49 PM
cornermike
Jul 30, 2015 06:37 AM
ltrmc02
Jul 22, 2015 04:50 AM
