2003 Polaris Predator 500
Old Apr 10, 2011 | 03:59 PM
muddytrails's Avatar
Default 2003 Polaris Predator 500
I cleaned the carb on the predator and it will not start it seems like it is not getting fuel what could be the problem
Old Apr 10, 2011 | 04:04 PM
Pull the fuel line from the carb,if its pumping out as you turn over,then you may have carb or other problems.Plus this a shim under bucket valve system,I had a couple come in that wouldn't run because valves were too tight. If its been a while since having them adjusted,may need to check into it! Don't know if this could be part of problem?? OPT
Old Apr 10, 2011 | 04:06 PM
Thanks I will try that
Old Apr 10, 2011 | 04:13 PM
Hey I tried that but it does not seem that fuel is flowing through the line at all
Old Apr 10, 2011 | 04:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe fuel pet **** is plugged. don't know if there is a fuel filter or not but can be that. maybe pull hose off petcock and see if fuel will flow out of tank directly?
Old Apr 10, 2011 | 04:24 PM
Check for inline filter blockage to carb,plus make sure the vacuum line from the fuel pump to the carb is in good shape,not split.Plus check fuel cap hose for venting properly.
Old Apr 10, 2011 | 04:53 PM
also when I fill my coolant overfill tank to the max after awhile all the coolant is gone but does not seem to be leaking
Old Apr 10, 2011 | 04:55 PM
Fill the radiator first, but leave cap off to make sure all air is purged when fan kicks on, top off radiator,then fill the overflow tank.
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
