250r in the woods
Old Mar 11, 2001 | 06:14 PM
cramman400's Avatar
how good is it in the woods
does it overheat often
is it good in the mud
what is the top speed
can you get 88 plastic on the 87
Old Mar 12, 2001 | 12:35 PM
PaRoostR's Avatar
I have a 250r and ride in the woods and love it. No it does not over heat very quick at all unless you get the radiator cloged up with crap and air can not get enough air. It is not very good in mud because it is two wheel drive and it is a two stroke but with the right tires it will go ok. Any year plastic will work on all of them but the seat latch is differant on the 86-87 and the 88-89 so you would need a 86-87 seat latch and up front under the hood the 88-89 use smaller louvers but they will work with both plastics.
Old Mar 12, 2001 | 12:58 PM
87r's Avatar
87r
My 87 has never overheated no matter how hard I run it even in the woods. I think an R is great in the woods because the steering is so good but it takes a little more work to keep the motor on the pipe in the woods than a 400EX. R's do OK in the mud as long as you keep your momentum up but they do spin easy because of the 2 stroke power delivery.
I think the top speed on an R is about 74mph stock.
Old Mar 14, 2001 | 05:48 AM
Darrin's Avatar
With a low end pipe and porting 250r's aren't good in the woods they rule. Big bore kits also help low end.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
