500x2 wont start,help
Old Apr 23, 2011 | 08:27 AM
DOC HOLIDAY's Avatar
Unhappy 500x2 wont start,help
Hi,my 2007 sportsman500x2 wont start.when i turn on the key,every thing goes nuts,the insturment panel light blinks,the fuel pump kicks on and off then everything goes off and comes back on again,keeps recycing over and over,and if i hold on the key it will start for a second then turn off.please help.
Old Apr 23, 2011 | 08:40 AM
Check the battery connections first, if connections tight could be needing a new battery?? OPT
Old Apr 23, 2011 | 09:18 AM
thanks,battery shows 12.8v,i think i will take battery to dealer to have it tested,i guess it could still be bad?
Old Apr 23, 2011 | 12:12 PM
battery test fine,any other ideas?please help
Old Apr 23, 2011 | 03:51 PM
Check under headlight pod for shorts in ignition switch wiring,speedometer connections, shorts in main wiring harness etc,could be a bare wire or ground problem OPT
Old Apr 23, 2011 | 04:44 PM
Seems like a bad starter solenoid,if i shake the wires on it the atv starts.all connections are tight,i ordered one from dealer,i will keep you posted,thanks for your help
Old Apr 23, 2011 | 05:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your talking about the solenoid on the frame from the battery, i would test it before you order one as they usually don't go. just turn the key on(not start) and jump the 2 big cables on the solenoid and if the starter starts to turn over then the solenoid is bad and if nothing happens(meaning starter doesnt turn over) then the solenoid is not the issue. imo
Old Apr 23, 2011 | 05:31 PM
Kerbbirds's Avatar
take batery cables off selenoid and check nuts under cables for tightness, seen several loose causing these problems
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
