1986 bayou 300 wont start
Old Apr 23, 2011 | 05:51 PM
SICRAPTOR's Avatar
Default 1986 bayou 300 wont start
hey guys. Well my old quad wont start. It's a 1986 bayou 300 2wd. The nuetral light comes on. (brand new battery fully charged) I jumped the soleniod and she cranks over. When I hit the starter button I get nothing, not even a click. Do you guys have any suggestions on what I can do to narrow this problem down? I'm thinkin it might be the run stop switch. I took it apart and cleaned all the connections but it's still the same. I checked the wires coming out of the switch with a test light and they are getting power, but when I hit the button they do not do anything. I just wanna make sure it's the switch before I buy a new one. Any help would be appreciated. Thanks
Old Apr 24, 2011 | 12:36 AM
Doctorturbo's Avatar
GOT BOOST!
If it's just a simple two wire switch just jump the two wires together and it should start because you took the switch out of the system.
If it does not, it's not the switch and is something else.
Old Apr 25, 2011 | 07:28 AM
never2deep's Avatar
check the wire on the starter. even if it looks tight it may not be getting a connection. this happens every now and then on my 400 bayou io just loosen the bolt and the tighten it back down.
Old Apr 25, 2011 | 09:30 PM
dakbee's Avatar
My 96 220 bayou was doing the same thing. Not sure how similar the wiring is but on mine next to the battery was the solenoid and a relay for neutral. My neutral light still came on but I had to tap on the relay to start it with the switch. I just removed the relay and made a jumper wire and that solved my problem plus lets me start in any gear
jgreerberube
Jun 21, 2015 02:27 PM
bvolks
Jun 13, 2015 08:14 AM
TJM
Jun 11, 2015 01:28 PM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
