99 Xplorer 400 oil/water seals for water pump
Old Apr 24, 2011 | 12:03 PM
trbojet1's Avatar
Default 99 Xplorer 400 oil/water seals for water pump
I'm in the middle of a rebuild for my 99 xplorer 400. I have a couple of questions:
1. Is it required to use the special tool to install the two seals on the water pump shaft? The motor is off the frame.
2. I bought a set of seals for the waterpump. There doesn't seem to be a difference between the two seals. Is there a way to tell between the water seal and the oil seal?
Thanks
Old Apr 24, 2011 | 12:19 PM
Thanks
Yes the two seals are different.(difference is the with of lip on one seal,one is thicker) you can use a small socket to seat them,but make sure the two small holes in the cavity are not covered for seals and bearing(check your manual) Just pry one seal out and match it up with the new one Replace both seals in the same position as removed! OPT
Old Apr 24, 2011 | 01:39 PM
trbojet1's Avatar
Thank you........
Old Apr 26, 2011 | 01:39 AM
mrtwostroke's Avatar
aftermarket gasket kits don't come with the special water seal. well not winderosa
I always buy that piece from polaris
Old Apr 26, 2011 | 08:29 AM
trbojet1's Avatar
Thanks. Will the other oil seal work in place of the water seal? I ordered an OEM water seal yesterday.
Old Apr 26, 2011 | 09:55 AM
Should work??,BUT I always installed them according to the way they came out! They are different for a reason! May be one seals coolant better because of the wider lip than the other?? OPT
MeadowlarkFarm
Nov 27, 2019 08:40 PM
cornermike
Sep 10, 2015 08:30 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
