400 xplorer boggin out in deep water??
havein trouble with my 2 smoke boggin out in water bout fender deep,..tryed wide open an tryed feathering throttle takin it easy,..some times itll keep an chuggin,..sumtimes its rope 30...ugggghhhhh!!!! drag it up on the bank an let water drain outta stock muffler,..an back to pond jumping in moments???
is there some kind of gasket where exhaust joins together an held by them springs?? an could it be getting water in exhaust at these joints?? an you mean snorkel the exhaust right?? was gonna check plug tomorrow as its not running right an popping an sputtering some now too,..maybe water shorting plug or wire,..or ignition system??? or is it possible water flooded exhaust to the point plug got wet an fouled out maybe???
Yes on the explorer 400 there is a slip on asbestos type gasket at the bend of head pipe,could be worn,allowing water in(usually loud if worn) yes snorkel the exhaust if going under water,plus still could be plug grounding out because of water OR all of the above! Might try electrical grease on plug and cap,plus all connections that are exposed to water. Lot of the mud doggers go to extremes to water proof their machines!
correct me if i am wrong but isn't the asbestos type donut only on the scrambler and trailblazer. my 96 sportsman and 95 xplorer have a steel on steel seal. They can get worn, but exhaust will leak. look for wet oil spots. but not all that likely to let water in with engine running. probably sucking water, the airbox drain may seep water from the bottom up, given enough time in the water.
ok,..i pulled the plug,..an no spark,..put new plug on it an plenty of spark!! put plug in an ran great,..took a few laps round 5 acer field,..an parked it,..later this evening fired it up to pul inside shop an it went to running crazy,..throttle gaining slop,..an loseing it,...this loss space in throttle is very irratic to the motor,..reving high an back real sincative,...an if you rev it up any at all itll back fire real loud when it gets back close to idel,..an reverse light dimely lite up an flickers some??? an its smoking real bad!! wounder if oil pump started working again???bout at my wits end with this thang!!
