CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
DS650 RPM Gauge Light remains on
Old May 9, 2011 | 03:37 PM
bobalay's Avatar
Default DS650 RPM Gauge Light remains on
The light in my rpm gauge remains on even with the ATV off and the key removed. I replaced the left light and headlight and I cleaned all connectors, applied die-electric grease then reconnected everything and all lights work, low and high, the ignition also works but I can't get the rpm light to shut off unless I unplug it from the harness.
Could it be a bad connection or wrong connection?
There is a black wire that comes out of the gauge into a gray plastic harness connector and if i unplug that single black wire the light shuts off.
Any suggestions much appreciated.
Old May 10, 2011 | 07:58 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Out of your key switch you have a brown and a white wire, they both go in to red wires, one from the harness and one from the tach. Try switching these two wires and your light should go out.
You don't say what year model you have or whether or not it is a Baja edition. These tachs were for the the Baja but a lot of us did the mod so that wwe could have them on all models. Somehow the instructions that came with the tachs only worked on the earlier black models and the Baja's.
Hope this helps. Let us know if not.
Old May 10, 2011 | 11:02 PM
bobalay's Avatar
Yes it's a 2003 DS650 Baja, I will test that out thanks for the info.
Old May 12, 2011 | 09:44 PM
bobalay's Avatar
OK, so I tried swapping the red & brown wires that connect to two red wires one of which has a purple stripe and still the light remained on. I also tried it with both the red and brown wires fully disconnected and the light still did not go out. Only after disconnecting the black wire coming out of the RPM did the light turn off.
Old May 12, 2011 | 10:13 PM
420Pimp's Avatar
I know your trying to get it right before total forfeiture, but honestly I would have just unplugged it by now,no worries.
speedbuff
13
Nov 11, 2020 10:16 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
