07 500EFI water temp sencer??
Old May 15, 2011 | 08:55 AM
sportsman rocks 's Avatar
Angry 07 500EFI water temp sencer??
cooling fan want come on hot light starts flashing full of coolant . put new fan in and still nothing,the water temp senser has two wires going to it, i thaut maybe i hook the two together it would tern the fan on and it does not. still trying to find my problem.
Old May 15, 2011 | 09:33 AM
Tonyxp's Avatar
Not sure if it is the same as the old ones but you should be able to test it. I am sure it works with the same idea. Pull it out and test it in hot water and see if the resistance changes.
Old May 15, 2011 | 01:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should be able to unhook the wire plug off the sensor and w/ the key turned on(not started) the fan should automaticly come on. if not then check to see if theres power to the fan it self.
Alex G.
Sep 11, 2017 11:38 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
