So I think I screwed up
Old May 18, 2011 | 05:44 PM
HaydenS's Avatar
Default So I think I screwed up
My Dumb$#@ tried to do the 3 headlight mod and screwed something up but I don't know what. First I had it wired and it blew the 2nd fuse from the left (looking as if you're sitting on the machine) which is a 20 amp fuse right when I turned the key. After I undid the wires and taped any copper showing the fuses didn't blow anymore. Instead the first 20 amp fuse on the left (looking at fuses while sitting on machine) started to blow. Everything seems to work on the Machine so I don't know what that fuse is for and have no service manual to see. I only have an owners manual and it shows nothing about what each fuse is for. Any help please
Old May 18, 2011 | 05:45 PM
HaydenS's Avatar
I used a four pin relay to do the mod too
Old May 18, 2011 | 06:18 PM
HaydenS's Avatar
Nevermind, I found the problem. ME <--Thats the Problem lol....When I hooked up the positive to the 12v receptacle on the side of the pod (lighter) I took of the little nut that the + wire hooks to so I could put my mod wire there too. Well I let the inside of the lighter come out ( I guess you'd all have to take one apart or just know what i'm talking about to visualize this) and when I put it back in I had it twisted 90 degrees so the + prongs inside the lighter were constantly grounding out. I'm glad I found the problem but I should get the DUMBASS of the year award for that even though it's only May LOL.
Old May 18, 2011 | 06:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
basicly you ground out the hit wire causing you to blow a fuse. it happens lol
Old May 18, 2011 | 07:09 PM
HaydenS's Avatar
Yep =) I wonder if the mod would have worked if I hadn't disconnected everything and found the problem first
Old May 19, 2011 | 04:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most likely if it wasn't grounded out it might have worked.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
