Warn 2500#, 3000# same?
Old May 24, 2011 | 11:01 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default Warn 2500#, 3000# same?
I was comparing the warn 2500 and the 3000 and the specs are identical in every way but one. The 3000 # uses 6 ga wire and the 2500 uses 8 ga wire. I thought this had to be an error but then looked at just replacement winches minus electrical wiring, components, and switches and they stated you'll have a 2500 or 3000 pending on wire size used. If this is true, I could or anyone one for that matter could turn they're 2500 winch into a 3000 with a quick switch of some wiring from the auto parts store. And if all that's different is the size of the wire, why such a price jump between the two. I know the difference in wire doesn't justify $50-$75 more. With that said, can anyone recall if the later sportsman's that were prewired, have 8ga or 6ga wire. I may convert mine to a 3000# I know it's 6ga at the battery but unsure without taking apart up under the box and fender near the contactor.
Old May 24, 2011 | 11:17 PM
atvkiller's Avatar
im not really sure i know the 2000 winch i got from harbor freits cam with 6 gage wire that i installed on my out lander still waiting to try it out still waiting to find a mud hole i cant handle with my 400 it goes through just about any thing i throw at it
Old May 25, 2011 | 02:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it is true about the gauge of the wire being the only differnce. you can turn a 2000 lb into a a 2500 lb w/ heavier cables as well. the thicker the gauge cable/wire the more power it can handle(same as in house electrical) thus bringing the load rate up.
Old May 25, 2011 | 06:32 AM
Well that's very cool to know. Does anyone know if the the sportsman's are wired with 6ga or 8ga from the factory. I was thinking 6ga all the way to the front but can't remember without digging into the bike.
Old May 25, 2011 | 07:51 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I was also thinking maybe the gear ratios are not the same???
Could also be- the 3000lb winch has either more wire woundings or finer (more wounds) in the armature which would draw more current- hence the heavier ga wire
I know going from an 8 to 6 ga wire will allow for more current- but both 6 or 8 ga wire can easily handle the draw of a 2500 - 3000lb winch motor. There must be more to it somewhere.
are the armature part #'s identicle?
Old May 25, 2011 | 09:03 AM
Every spec is the same according to the warn website with the exception of the size wire used. If you look here you'll see that you can purchase just a new winch for less to replace an old worn out unit and they claim wiring makes the only difference.http://www.google.com/url?sa=t&sourc...BWrsUw&cad=rja
Old May 25, 2011 | 09:15 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
the older (discontinued) 2.5ci does not match the 3.0, but the new XT25 & XT30 do look like they have the same parts as mentioned above.
2.5ci
.7kw motor
204 amps
motor part # 36031
ratio 136:1
7' / minute
15.4 lbs
XT25
.7 kw motor
157 amps
motor part # 65100
stage 1 gear # 75002
stage 2 gear # 75004
stage 3 gear # 75005
sun gear 12T # 74999
ratio 154:1
4' / minute
13.4 lbs
XT30
.7 kw motor
198 amps
motor part # 65100
ratio 154:1
5' / minute
13.4 lbs
I would think there still has to be something to regulate the amps
because you can't rely on the wire to act as a resistor- it'll heat up. The winch has no idea if it's hooked to a 6 or 8 ga wire...
Old May 25, 2011 | 09:57 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I guess you're right- the only part I don't get is, if the only change is the wire going to the battery- then the battery is what will determine how many amps the winch will get- because you can easily put 200 amps through a 6 or 8 ga cable. Hell- I have a 1000 CCA (cold cranking amps) marine battey in my boat with 8 ga wires going to the starter (installed from the factory) and that wire easily handles 15 seconds of cranking without heating up- so I really don't get how going fron a 6 ga wire to an 8ga wire would translate into an extra 500lbs of winch.
The xt25 pulls 157 amps whereas the xt30 pulls 198 amps- you're only talking about another 41 amps between the two- that's nothing for an 8 or 6 ga cable- if the battery has the juice, why wouldn't it always supply the max amperage to the motor?
I feel like there's something missing in the equation
Old May 25, 2011 | 05:31 PM
I'm kinda thinking of it like sucking air through a straw (8ga) and air through an even larger straw(6ga) Both will produce the same effect but the larger will pull a greater amount of power at one time, with greater ease. In that thinking I can see the winch motor being able to pull more power at any given point with less effort there-by increasing the amount of torque the motor can output.
Old May 25, 2011 | 07:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
all i know is wat i read about the differnce between the 2 and knowing that heavier wire lets you pull more power. other then that i leave it to the experts to figure out.
