Advice on piston stuck in caliper?
Old May 30, 2011 | 11:04 PM
Canyon Doug's Avatar
Question Advice on piston stuck in caliper?
Have an oldie... 1989 Big Boss. It uses a caliper to grab the transmission... Took off the caliper to inspect nd the piston is stuck all the way in. Brake fluid comes out the line when pumped... but not near enough force to move the piston out. Looking for any and all suggestions... Have heard of compressed air... Thanks for any help.
Old May 31, 2011 | 02:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. sounds like the piston is rusted into the caliper. chances are you'll find a ring of rust near the very outside edge of where they meet in which it will always leak if you try to clean it up when you get it apart. had the samee isue w/ my car and couldn't find a rebuild kit(and i doubt polaris has on either) so i had to replace the whole caliper. you might be able to use compressed air if you have enough pressure and a good seal to force air into it. i had to use a pry device to get it back enough off the disk. good luck.
Old May 31, 2011 | 05:09 AM
Caliper seal/piston rebuild kit #1930666 for transmission brake, kit #1930665 for front brakes are still available as long as the calipers aren't corroded inside,and need replacement as mentioned. OPT
Old May 31, 2011 | 07:47 AM
Default Thanks for the quick replies.
I appreciate the quick replies. - Doug
Old May 31, 2011 | 10:57 AM
Doctorturbo's Avatar
GOT BOOST!
Giv it a BIG volume shot of air........it'll pop. Be safe and work your way up from a small shot to a big shot.
Old May 31, 2011 | 05:04 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i'm suprised thewy still make kits. should have checked the parts break down i guess.
Old May 31, 2011 | 07:45 PM
420Pimp's Avatar
Buy new caliper_Problem solved
No need to thank me, your welcome
Steeldon
Sep 9, 2015 09:38 AM
atvcollector
Sep 8, 2015 05:11 PM
toonces
Sep 5, 2015 01:14 PM
Jason Richards
Sep 4, 2015 06:17 PM
snowolson
Aug 31, 2015 03:51 PM
