Speedo- Polaris 600
Old Jun 4, 2011 | 05:23 PM
ofie's Avatar
Default Speedo- Polaris 600
Can sensor for the speedo/ mileage go bad? Its mounted on the Right wheel, can it short out from the water/ mudding?
Old Jun 4, 2011 | 05:32 PM
They can go out at ANY time!! muddy or clean trail riding. Replaced them on a lot of different machines. Usual signs are no speed indicator or mileage accumulation. OPT
Old Jun 4, 2011 | 06:21 PM
ofie's Avatar
Smile
I went ahead and ordered one.
Thanks,
Old Jun 6, 2011 | 01:09 PM
Big600twin's Avatar
Quick and easy repair did mine last year. Was your only symptom the speedo not working?? AWD is attached with the speedometer cable so if the speedo doesn't work and AWD is out then it could be something other than the hall effect sensor.
Old Jun 7, 2011 | 06:24 AM
TLC's Avatar
TLC
Polaris has not used a cable operated speedo since 1998 I think. I like the older cable speedo like on our 97 500 Sportsman, it was smashed off and in a roll over yet the AWD still worked fine, unlike the wire operated speeds they use now.
My Hall Effect when out a few years back, for $80 I just though it was not worth having a speedo and trip meter,only the hour meter works and it is so fogged up I can barely read it.
Old Jun 7, 2011 | 03:47 PM
Big600twin's Avatar
Sorry didn't mean to misname the part. I know it is not an actual "cable" I meant the cluster/speedo and if I remember correctly for the Sportsamn 600, if it fails, it also effects the awd drive system. Sometimes that can help with the diagnosis as to whether the entire cluster/speedo is out or if it is a hall sensor issue. Maybe we are just stating the same thing. In my situation it was the hall effect sensor....
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
