2000 400 scrambler
Old Jun 5, 2011 | 10:16 AM
tims's Avatar
Default 2000 400 scrambler
i am needing to know how to remove front driveline so i can remove the corner bolt on starter that also holds the recoil starter housing?
Old Jun 5, 2011 | 11:19 AM
midnightxplorer's Avatar
I lost ya, you shouldn't need to.
Old Jun 5, 2011 | 02:53 PM
tims's Avatar
the driveline keeps the long bolt from coming all the way out.i need the cover off to get to the starter bolts.
Old Jun 5, 2011 | 05:45 PM
Bolt can stay in cover!! Just loosen all the way and wiggle cover out with long bolt in!! Tough being a mechanic sometimes because engineers don't check or care when building things at times! Aint easy,but cover will come off! I've cussed em too! P.S. Bolt has to be partially in cover when replacing! When you get it down past the prop shaft you can pull back on the bolt and line it up with case threads and push in and tighten. OPT
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
