oil in airbox on xp850
Old Jun 6, 2011 | 05:17 PM
lawnboy2121's Avatar
Default oil in airbox on xp850
does anyone know of a problem with oil blowing into the airox on the 850s. I heard a baffle warps in the valve cover and causes the oil to blow into the airbox . Anyone heard of this and if so any info would help i am looking at buying a 2011 850 thanks
Old Jun 7, 2011 | 08:55 AM
BlackRaptor's Avatar
Mine had 150 miles and 11 hours and zero oil. But it's still very new and i'm pretty easy on it.
Old Jun 7, 2011 | 08:55 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Very common according to the forums posts i read. What a shame for a top of the line machine. Polaris should hang their heads in shame.
Old Jun 7, 2011 | 11:16 PM
awsume800efi's Avatar
i agree alot of the forums are plauged with reports of oil in the air box i own 2 850's and only one time did i find a splatter of oil on my air filter and it was my 11 model not sure what i did to cause it but i am a little nervous now. i do and always will like polaris but i am tired of these pcv/oil in the airbox issues i mean come on how hard can it possibly be to fix this my fear is polaris is plain *** to cheap to do what they need to do so they keep trying to give us bandaids instead of a proper fix i hope they get it rigt soon
Old Jun 8, 2011 | 08:02 PM
weedy's Avatar
Question
I think they have steadily gone down hill on quality since 2002. My 2001 and 2002 Sp 500s seem to be better made.
Old Jun 22, 2011 | 09:22 PM
tmzg29's Avatar
I lost about 3/4 of a quart of oil from the motor that went into my air box. It smoked so bad the guys behind me had to stop because they could not see the trail. Read my other posts..............I am very frustrated with polaris right now and I am on my 6th Polaris ATV the the newest one has all the issues. 2010 Sportsman 850 XP. I am starting the think the XP stands for Xtreme Piece of SH*%.
Old Jun 22, 2011 | 10:10 PM
tmzg29's Avatar
Check this thread out.....common problem on the 850's
oil in air box - Polaris ATV Forum
Old Jun 23, 2011 | 04:03 PM
TackWest1's Avatar
Default possible solution to 850 oil in airbox
I found lots of oil in my 850's airbox as well, but I found an easy solution. I simply added a "T" that I made from copper pipe into the line that goes to the airbox. I located it right behind the sidepanel and put a small filter atop it. point the top up. I also took the breather top off and put a piece of Scotchbrite pad rolled up to cover the inside walls of the breather, but left the center open to drain any oil that might accumulate there. I did this after I put a new improved breather and valve cover that was assembled at the factory in and didn't solve the problem. My theory is that the small felt pad that covers the outside of the breather isn't stopping the oil that gets by the baffle and coupled with a high vaccuum inside the airbox at high RPM that sucks the oil up the breather pipe right into the airbox. After several fast rides of 30 or so miles, there is no oil in the airbox. Good luck.
Chris
Old Jun 24, 2011 | 07:37 PM
bodon's Avatar
Do tou have any pictures of what you fabricated,Thanks!!
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
