Baja 90 rear brakes
Old Jun 8, 2011 | 08:40 AM
reckleys's Avatar
Default Baja 90 rear brakes
My hand brake has a brake fluid reservoir with a plastic window on the side which is broken. Will the brakes still work? The reason I ask is that I have a 50cc with the same problem and the brakes work. However on my Baja 90 there is no pressure in the lines when I squeeze the hand brake.
Thanx in advance,
Old Jun 14, 2011 | 02:05 PM
ATV Connection Reporter's Avatar
Your question has been selected by the editors for our Ask the Editor column!
Originally Posted by atv connection
Indeed an opening in what must be a completely sealed system to operate would cause a permanent loss of pressure/ brake function. Within a hydraulic brake system, as you apply pressure to the brake lever, a pushrod exerts force on a piston within the master cylinder causing fluid from the reservoir to pressurize the entire brake line.
To read the rest of the response, click here!
Thank you for submitting your question.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
