will changing starter on '86 Bayou 300 effect timing
Old Jun 16, 2011 | 10:27 PM
das fisch's Avatar
Default will changing starter on '86 Bayou 300 effect timing
I just changed out the starter on my 1986 bayou 300 2x4, and had to removed the cover on the left side of the engine to line up the starter shaft with the gear on the chain.
after this was done though I know can only run the machine with choke full on. cleaned carb well and no real difference.
didn't know if removing this cover and changing starter would change timing and effect how it runs with choke off... basically just dies when choke is turned off.
Old Jun 20, 2011 | 05:45 PM
Hayashi's Avatar
Wonder if there is an air leak in the air intake system and now machine is running too lean and you have to make it run rich by turning on the choke...
jgreerberube
Jun 21, 2015 02:27 PM
rcappie4
Jun 13, 2015 05:28 PM
Fullblast
May 26, 2015 12:38 AM
Tree Farmer
11
May 12, 2000 01:18 AM
Smokinthebear
May 7, 2000 08:01 PM
