Artic Cat 400 2007 Please HELP
Old Jun 18, 2011 | 05:21 PM
jpwalkerjr's Avatar
Default Artic Cat 400 2007 Please HELP
when trying to strt this machine it spits and sputters, using choke cleaner and a jump it blows water out the exhaust, in a 15 minute period of trying to start it a puddle about 1 foot by 3 foot long, appears to be water????
thanks for answering
Old Jun 18, 2011 | 06:59 PM
mudslinginfool's Avatar
Does it in the Mud!
was it under water the last time you rode it? Water may be sitting it the exhaust and fuel lines. unscrew the screw on the bottom of the carb. and let it drain out for a minute or so,till the water is out(if there is any). Or just empty the gas tank and refuel with fresh gas. Change the spark plug,check the air filter and clean if necessary ,then try to start it. may check the oil as well,if its milky white,you have water in it and needs changes asap.
Old Jun 19, 2011 | 04:53 PM
jpwalkerjr's Avatar
Default thank you that fixed it.....
took awhile but your advise helped, also the fuel filter was 1/2 clogged.
Old Jun 20, 2011 | 10:15 PM
Does it in the Mud!
good deal. having a fuel filter helps alot,i need to add one myself
kodiacrunner
Oct 4, 2015 11:52 AM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
