2003 Arctic Cat 500
Old Oct 21, 2010 | 08:15 PM
tbent4098@sbcglobal.net's Avatar
Default 2003 Arctic Cat 500
I own a 2003 500 Arctic cat and want to drain the radiator. I don't see any drain plugs. . Any ideas other than just pulling off the lower hose! Thanks , Tom B.
Old Oct 22, 2010 | 07:30 AM
cupsz71's Avatar
Cool
Find your waterpump.
There's a 10mm bolt w/washer tapped into the very bottom of it. Pull your rad cap off, and take the bolt out. Your anti-freeze will drain NP.
When refilling tighten the bolt (carefull...it's aluminum!) top off the rad and fire up the machine. As the machine runs it will suck the anti-freeze down/thru. Keep adding till the rad is topped off the machine is up to temperature AND the cooling fan kicks in. THis will ensure that all the air is out of the system.
Re-install the rad cap. Your done.
Old Oct 22, 2010 | 09:52 AM
swampyjunior's Avatar
I agree with Cups.
I will also attest to the fact that if you say accidently ripped the lower radiator hose off with a stick. The antifreeze drains VERY quickly! So if you want to drain it by using the lower hose it is faster but I would not reccomend using the stick.
Swampy
Old Jun 20, 2011 | 09:43 PM
Mud-D's Avatar
Thanks guys! I just did mine tonight. It's funny how pepper turns the pretty green into such an ugly colour :-D
D
Old Jun 22, 2011 | 07:54 PM
Mud-D's Avatar
Okay, now I have a stupid question. Should the coolant be diluted? Is there a special type to use? (oh I guess that's two stupid questions)
I dumped the old stuff and put in pre-mixed rad fluid. Today I took it for a spin down the alley. I was out less than 10 minutes. It didn't sound right so i came home. When I turned it off the fan ran for about 10 minutes.
That is so odd. My girl could go for a whole day without over-heating.
Thanks
D
Customer Service #1
May 15, 2020 08:46 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
brad patnoe
Sep 23, 2015 06:44 PM
Hw00d
Sep 10, 2015 08:53 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
