scrambler 500 w/hpd jet kit.
Old Jun 22, 2011 | 08:28 PM
nation's Avatar
Default scrambler 500 w/hpd jet kit.
well th jet kit never sold so i decided to install it based on everyone saying its a great upgrade. will i did everything like the instuctions said and i think it running rich. it fires up and idles but its choppy. the plug is new.
the kit came with a 165 main,is that to rich?i ride mostly sea level to 3800ft.
did i miss a step ?
i drilled out the 2 holes
i turned out the fuel screw 3 turns
installed the new jet tube and bottomed it out like the stocker with the notch in the same place.
and i cleaned it for good measure.
Old Jun 23, 2011 | 05:20 AM
Carb tuning takes a little time! Try going back down to a 160 main(155 should be stock) and fuel air screw DOWN 1/2 turn to 2 1/2 turns,then test ride and "plug chop", that is test the color of the plug,should be medium tan color. If still running a little rich at idle,you can further go down on fuel /air screw mixture(which mainly affects idle) and can fine tune it a little more by dropping carb needle if still a little boggy. Just a process of trial and error! ALWAYS best to have a few different jets on hand as "kits' don't always hit it "dead on" depending on altitude,etc. OPT
Old Jun 23, 2011 | 06:09 AM
ftwflh's Avatar
What pipe are you running?If it is disc type you can add discs to open it up some to lean out or take some out to richen it a little.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
