Gettn agrivated
Old Jun 23, 2011 | 03:08 PM
KREIN917's Avatar
Default Gettn agrivated
Hello,
i have a polaris 400 scrambler and i purchased it used.
Well it was running great then... I added polaris 2 cycl oil mix to the oil tank and all the problems started. Such as.. Plastic body melted near exhaust by seat. Mis firing, fouling, running hot, no power, battery died. I cleaned out oil tank flushed most lines, not the one from pump to carb. Changed oil line filter, spark plug.
Cleaned out carb, adjusted air/fuel mix. Started ok after 2 minutes it was back to running like junk. I did notice while running it with no battery that the lights were very dim. Including the dash lights. It did pull start and run but still poorly. My next guess would be to pull off and flush last oil line to carb. And or clean magneto?? Or do they have an alternator? I put in the quicksilver oil the previous owner used. I feel its either a inter mitten spark or fuel problem?? Any suggestions??
Old Jun 23, 2011 | 03:30 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
What does the spark plug look like?
Old Jun 23, 2011 | 04:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by KREIN917
Hello,
welcome to the forum. the first issue you need to fix is buying a "battery". you should not run these bikes w/ out a battery or does damage to the electronics. this is turn can maake the bike run poorly as you mentioned(nothing to do w/ the oil) as the bike is not getting enough power to give good ignition to make the bike run right. you can also burn the charging system out which it would not run if it can't make spark. imo
Old Jun 23, 2011 | 04:44 PM
user493's Avatar
Moto Psycho
Don't run it without the battery. It can blow all the light bulbs. Possibly more damage.
crcmech
Oct 6, 2011 09:39 PM
meddy293
Dec 2, 2010 09:41 PM
doublejay
Worst Stuck Photos
10
Mar 30, 2009 06:59 AM
Kernel
Mar 31, 2007 01:30 PM
