What is a good kids ATV?
Old Jun 27, 2011 | 09:25 AM
keithert's Avatar
Default What is a good kids ATV?
We have a Panterra 90 CC atv that my 7 year old rides. It runs pretty well and gets through regular trails. The engine power seems okay for his level. But in pea gravel or mud it gets stuck which frustrates him. Is there a 110 cc or less ATV that doesn't get stuck easily in these situations? Should we be looking for units with larger tires?
Old Jun 27, 2011 | 09:31 AM
scootergptx's Avatar
Supersock
Hired Gun!
You can't go wrong with a used lt80. Easily build it up for more power as needed.
Old Jun 27, 2011 | 09:40 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Have you thought of a larger rear sprocket? or a smaller front sprocket? 2 teeth less in the front, or 6 added to the rear, would give you more low end power.(top speed would be less)
Old Jun 27, 2011 | 10:35 AM
keithert's Avatar
What are the good points on the LT80?
Old Jun 27, 2011 | 10:50 AM
Supersock
Hired Gun!
Dependable. 06 and earlier were 2 stroke, easy to work on. Lots of them out there so parts aren't that hard to find.
Worst thing about them is they are a little pricey. But you can get one of these, get your son some good years of riding and learning and then sell it for a decent price. (well depending on condition)
Old Jun 27, 2011 | 08:17 PM
isovapor2112's Avatar
If you want to stick with the Chinese, I have 2 Taotao ATA-125D atvs. They are 110cc and the engine is solid. My 6 and 8 year old boys love them. Check them out here:
ATA 125D - Big Tire
Old Jun 28, 2011 | 07:49 AM
keithert's Avatar
ATA 125D - Big Tire
How long have you had them? Any issues? That might be a good option.
Old Jun 28, 2011 | 09:02 AM
I have had them since Christmas 2010. I have had to replace the left handle bar switch on one because the lights would not work. Cost me $20 and 10 minutes. I have had to replace the rear brake pads twice on both. It seems that if they get water and sand between the rotor and pad, the pad will shred. Pads are $2.50 a set. I have tightened the chain on both twice. Loosen 4 bolts and pull the axle backwards then retighten. I change the oil with 700ml of SuperTech 15w-40 every 3 months. Changed out the spark plug to NGK C7HSA. I had to find replacement o-rings for the oil dipstick ($2 at NAPA). The little engine is solid and have had no problems. Added an inline fuel filter ($2). The boys have a blast on them. They are great for them to learn how to ride. Would I buy these again? Yes. Will I buy another Chinese ATV when my boys get older? No. I will get them a used Honda, Yamaha, or Kawasaki. Hope this helps!
Frisky2050
Apr 9, 2020 11:19 AM
kelleycully
Sep 15, 2016 02:57 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Robbbb55
Jul 8, 2015 02:11 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
