2011 Polaris 500 noise...
Old Jul 3, 2011 | 10:36 AM
MTGunner's Avatar
Default 2011 Polaris 500 noise...
I have just 15 hours on my new Sportsman 500. It has less that 200 miles on the odometer. After a 70 mile trip yesterday I noticed a low thumping noise in the belt drive case as it is idling. Also, it seems to have a squeal upon riding uphill. My hearing is not that good but I swear I hear a slight squeal. Is this normal? Thanks for any and all input. MTG
Old Jul 3, 2011 | 11:46 AM
Belt thump noise is normal in neutral,especially if you give it a little throttle and let off. This is belt flex If you've been riding at low speeds in high range can cause belt stretch though from excess heat also. Be sure to use the proper gear range. You can have a little belt/one way bearing squeal noise on down hills as its breaking in. If the thumping continues while in gear,I would pull the cover and check for possible belt separation(worst case scenario) or belt stretch. OPT
Ramman1
Aug 11, 2022 01:53 PM
erntee61
Aug 9, 2015 02:54 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
