YFZ 450 cold start issues please help
Old Jul 17, 2011 | 08:26 AM
oilboss903's Avatar
Default YFZ 450 cold start issues please help
I have 2004 yfz 450... It has k&n filter aftermarket exhaust and is to my standards crazy fast, however it won't cold start worth a crap: if its a cold start not meaning outside air temp: it will fire with the choke off and die. if u push in on the throttle it will pop and cough and hard to keep it running. If u apply choke it makes it impossible to run.... however after about 3 minutes and its hot it will idel just right. hop on it and it runs like a top. Any ideas?
Old Jul 17, 2011 | 10:33 AM
RoyP's Avatar
has it been jetted to match the aftermarket air filter and exhaust?
Old Jul 17, 2011 | 12:32 PM
nelson61339's Avatar
From: trx 90, 2010 honda fouurtrax es recon 250, 2011 honda efi es rancher 420
when you cold start your nott supposed to punch the throttle, it ruins the engine then it wont cold start
Old Jul 17, 2011 | 01:08 PM
Dan1724's Avatar
Have you checked your valve clearance? A bike with properly adjusted valves should fire over instantly, assuming that all else on the bike is in proper condition. I haven't used my choke in over a year, and I spend a LOT of time riding in the winter (-30 to +30 temps from November to March).
Old Jul 17, 2011 | 01:34 PM
oilboss903's Avatar
it was rejetted some time ago. a few rides ago this was not an issue. I have changed fuel and plug.... it will not even fire with choke on at all..... if it is running and u hit the choke, just dies..... with no choke without adding throttle it will not run or idle until its up to temp with the fan on...... until its hot if u hit the throttle it justs pops and spits..... where i am puzzled is that it wasnt this way a few rides ago.... it never liked to idle much after the mods until it was warm but, if u choked it it would then when it warmed, take it off and you were good. now its just weird, i may just have to take it in i supose.
Old Jul 17, 2011 | 01:36 PM
oilboss903's Avatar
I have not checked the valve clearance.... i will google and see how to do it...
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
