1998 Big Bear TOO EXPENSIVE, HELP!!
Looking for a new/rebuilt/used carburetor in good shape for my 1998 Big Bear YFM350FWBK the new ones go from $600 to $450 can not afford that.So if anyone knows where I can get one at a reasonable price please let me know. david_vallarino@hotmail.com
Thanx but can't do, the old one is broken missing a piece, and I'm away from shops ! live in the boonies
You can also check eBay for a carb, might be a good used or even rebuilt one there, I've had good luck finding parts for my quads on eBay.
Just did a quick search on eBay... found several new carbs for Big Bear 400, 2000 model, don't know if that is similar to yours or not, but price is good...160 bucks for a new, unused carb. Check with a dealer to see if that will work, at most you may only need to rejet for your 350 if it will bolt up. Hope that helps you. ( I did a search for Big Bear carb in ATV parts, take a look).
Thank you guys for your input, Ricky from TX called the No. you gave me unfortunatly did not have, 95 wolv, I tried e bay first could not find one like mine but the question I have now is wich other carb will fit, mine does not bolt anywhere it's held by hoses from either end so how would I find out wich other carb would fit?
Replace the broken part with new from Motorcycle Parts, Motorcycle Accessories
exmotocrosser
Sep 13, 2019 06:12 AM
Elkaholic
Sep 6, 2015 02:44 PM
1998, 350, 4wheeler, aftermarket, atv, bear, big, build, carburetor, carburetors, difference, expensive, parts, rebuild, yamaha
