1998 Big Bear TOO EXPENSIVE, HELP!!
Old Jul 18, 2011 | 06:49 PM
davedamex's Avatar
Exclamation 1998 Big Bear TOO EXPENSIVE, HELP!!
Looking for a new/rebuilt/used carburetor in good shape for my 1998 Big Bear YFM350FWBK the new ones go from $600 to $450 can not afford that.
So if anyone knows where I can get one at a reasonable price please let me know. david_vallarino@hotmail.com
Old Jul 19, 2011 | 01:32 AM
HeftyLefty's Avatar
Have a motorcycle shop rebuild yours. Parts aren't that expensive, and 3 hours labor ought to have it like new. I'd say 200-300 ought to get it done. Check around for best labor rate.
Old Jul 19, 2011 | 12:52 PM
davedamex's Avatar
Thanx but can't do, the old one is broken missing a piece, and I'm away from shops ! live in the boonies
Old Jul 19, 2011 | 03:21 PM
HeftyLefty's Avatar
Replace the broken part with new from Motorcycle Parts, Motorcycle Accessories
Old Jul 19, 2011 | 04:43 PM
95wolv's Avatar
You can also check eBay for a carb, might be a good used or even rebuilt one there, I've had good luck finding parts for my quads on eBay.
Just did a quick search on eBay... found several new carbs for Big Bear 400, 2000 model, don't know if that is similar to yours or not, but price is good...160 bucks for a new, unused carb. Check with a dealer to see if that will work, at most you may only need to rejet for your 350 if it will bolt up. Hope that helps you. ( I did a search for Big Bear carb in ATV parts, take a look).
Old Jul 19, 2011 | 05:14 PM
davedamex's Avatar
Thank you guys for your input, Ricky from TX called the No. you gave me unfortunatly did not have, 95 wolv, I tried e bay first could not find one like mine but the question I have now is wich other carb will fit, mine does not bolt anywhere it's held by hoses from either end so how would I find out wich other carb would fit?
Old Jul 19, 2011 | 05:17 PM
davedamex's Avatar
Wish I could it's the main body that broke at the air intake jet Thank you anyway
Old Jul 19, 2011 | 05:28 PM
95wolv's Avatar
by bolt, I meant it would go in place of, sorry. Call a Yamaha dealer and ask if they can cross reference the carb to see in the ports are the same size to fit your intake, I can't see there being much difference between the 350 and 400, Yamaha used a lot of similar parts on the Big Bear/ Kodiaks, the blocks are pretty much identical, just bigger bore or longer stroke to make the cc difference.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
