2003 Honda 400ex
Old Jul 22, 2011 | 01:56 AM
RaiNBowxzz's Avatar
Question 2003 Honda 400ex
alright so i bought a this quad about 3 days ago and i'm having a concern. So i haven't taken it out for a real ride yet but i do turn it on and ride it from the backyard to the garage. Well when i got it home i took a quick ride around the neighborhood and when i got back it was really hot on the sides. well i let it cool and drove it about 20 yards and the engine got hot. is this normal or should i be concerned
Old Jul 22, 2011 | 05:03 AM
95wolv's Avatar
Any mods like exhaust, vented airbox, etc? if it wasn't rejetted after intake or exhaust mods, it would be lean and heat up fast. How is the oil? is it low, or really dirty? that can give you problems too. Keep in mind, this is an air cooled engine, it relies on moving air to keep it cool, if you just putt around in the back yard, it will get hot fast. Does it roll easy in neutral? if the driveline is binding up, that will put more load on the motor. Clutch feel tight? slipped clutch will heat up fast. Lots of things to check, give us a little more info on the quad, and we'll see if we can help you more.
Old Jul 26, 2011 | 03:26 PM
quadtrx400ex's Avatar
Default 2003 Honda 400ex
i have a 04 and i noticed it gets really hot too but that's like after 2-3 mins of riding slowly at 20-30 mph i would check the oil and it might be running lean.. i am going to change my oil this weekend and see if that helps i am also going to clean the air filter ill get back to you and see if it helps it!
Old Jul 30, 2011 | 12:32 PM
i did all that on mine and i was thinking about it and its not a concerrn that atv is air cooled and you need to be moving or it will heat up (not sever) it will be fine i took it oon a long ride and it worked fine
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
