haweye rear slanted
Old Aug 4, 2011 | 02:43 PM
kg5769's Avatar
Question haweye rear slanted
My brother asked me to look at his hawkeye because the rear left tire was slanted. I looked it over and see no issues anywhere, frame is good,axle is not broken, shocks and all are fine.. why is it slantes and is there a way to fix it?
Old Aug 4, 2011 | 02:45 PM
snow racer's Avatar
Even tire pressure?
Old Aug 4, 2011 | 02:50 PM
kg5769's Avatar
Right at 7 psi on both rear was at 5 psi when i started looking.
Old Aug 4, 2011 | 05:46 PM
snow racer's Avatar
What. kind of cail ajustment is it
Old Aug 5, 2011 | 11:15 AM
kg5769's Avatar
I just added some pictures maybe that will help. I have never worked on a atv so i am lost. I talked more about it to my brother and he said he has not been rough and he has not been out with it in a few months but he does ride his 2 kids and wife all at once. So close to 600 lbs at once on it... got the rear jacked up and not a crack or anything on frame and no axle movement broken wise.......
Old Aug 5, 2011 | 06:28 PM
snow racer's Avatar
One spring is stiffer than the other.
Old Aug 7, 2011 | 04:27 PM
HawkeyeRider's Avatar
What year is the Hawkeye? Also..did you check the mounting plate the sway-bar is welded to? Earlier models tend to crack near the welds. Last of all, I know you said you checked the frame, but take a real close look at the front mounting tabs for the suspension arm. The 06 models were weak and would crack where welded to the sub frame.
Old Dec 27, 2011 | 07:44 PM
skookrider's Avatar
Default hawkeye trouble
Check the rear subframe closely.These machines are known for
frame cracking.Also check with your dealer for recalls on this model.
My 2006 had a recall for steering stem and lower a-arm problems.
Fix it and sell it, nothing but problems.
Good luck......................
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
