warrior start troubles
Old Aug 6, 2011 | 07:31 PM
Wuwarrior's Avatar
Default warrior start troubles
I have a '92 warrior 350. The warrior won't start, I test the battery and it is running at full voltage. When I start the ignition it drains the battery down to four volts. I've tested from the starter motor to ground and there is a dead short. There is also a dead short present from positive battery terminal to ground at all times. I pulled the starter out and there was no sign that it was seized. I also tested the solenoid and it is fully operational. I can however jumpstart the quad with another batttery. Would this be a result of the starter motor shorting out?
Old Aug 6, 2011 | 09:04 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
so if you change the battery source it starts fine? sounds like you have a bad battery
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
atving
Nov 17, 1999 09:24 PM
