2001 yamaha blaster help!!!
Old Aug 26, 2011 | 10:21 AM
dblaster01's Avatar
Exclamation 2001 yamaha blaster help!!!
i have recently been trying to fix my 01 blaster. new piston, rings, rebuilt carb, new spark plug, changed the oil, and for some reason its smoking like crazy, white smoke just billowing out the exhaust.
any help would be greatly appreciated, im just stumped
Thanks again
Old Aug 27, 2011 | 11:32 AM
Terrellster's Avatar
Thanks again
White smoke, usually equates to blue smoke.... Too much oil in the mix (If mixing) or something's wrong in the carb if you're using the factory oil injection..... May be running too lean. needs more fuel. I'd guess too much oil.
I've done some rebuilds in the past, that took a little bit for the rings to seat and the smoke slowed as it "broke in".... but I wouldn't have called it "billowing".
Old Aug 28, 2011 | 01:24 PM
CokeZero's Avatar
don't trust factory oilers. mix it yourself.
Old Aug 28, 2011 | 06:06 PM
That's a running debate..... It's the owner's call.... I have had both and both worked well.... The injection was smoother and less smokey.... The Premix is on a faster 2 stroke that's had mods.... It was that way when I purchased it. But I would have no issue running a slightly bored 2 stroke Yamaha with it's factory injection.
Old Aug 28, 2011 | 06:28 PM
JLsparky7's Avatar
Sounds like you might have a leaky crank seal sucking in trans oil... Get the oil injection delete kit and run premix.
Old Aug 29, 2011 | 09:11 AM
dblaster01's Avatar
up to this point ive cleaned the carb again and blocked off the oil injection and nothing seems to be slowing down the smoke... is it possible my reeds are bad?
Old Aug 31, 2011 | 11:18 PM
JLsparky7's Avatar
Sounds like you have a bad crank seal or your cases need to be split and resealed... Its sucking trans fluid into your crank and burning it.
Hunter100us
Oct 7, 2015 11:46 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
maxjung
Jul 14, 2015 03:10 AM
