paul turner type6 pipe/psi big air carb
Old Mar 14, 2001 | 06:48 PM
ronhonda's Avatar
two questions
will anyone wit a paul turner type 6 pipe write in with comments on their likes/dislikes, what kind of gains did you get, and what kind of setup are you running?
also does anyone have the big air carb by psi?
how easy is it to tune? what kind of gains? will it mount to a stock motor? how much? and do you like it? and do you need a twist or thumb throttle?
thanks in advance
ron
Old Mar 15, 2001 | 12:08 PM
retro's Avatar
I have a 38mm Lectron carb. It is very similar to the PSI carb. It fits good with my RAD valve and is currently set up with my thumb throttle.
Jetting is very diferent than any Keihin carb.
The metering rod controls the idle, pilot, needle, and part of the main circuits. The power jet is actually a Mikuni pilot jet which is hooked up directly to the float bowl and feeds into the the intake side of the carb before the slide.
ERIC
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
