1997 Yahama Wolverine Brake Problems
Old Sep 7, 2011 | 03:56 PM
doverust's Avatar
Default 1997 Yahama Wolverine Brake Problems
My rear brake (foot and hand brake) does not work. I replaced the master cylinder but the brake pedal when pushed down hits the bottom with no resistance. I tried bleeding air out of the lines but there is no pressure in the lines to even push the fluid out...all it does is dribble out.
Any suggestions?
Old Sep 7, 2011 | 09:50 PM
papa hogg scoot's Avatar
Loved
Community Favorite
What kind of condition is your brake caliper? what kind of condition is your brake line?
Old Sep 8, 2011 | 12:41 AM
JLsparky7's Avatar
The air isnt getting out of the lines. Crack open the bleeder valve on the caliper a little and let it gravity drain for an hour or so. Keep the MC full. Then rebleed the brakes.
Old Sep 8, 2011 | 07:31 AM
Loved
Community Favorite
We just need to know if caliper isn.t pulling air back in when system is working!
Old Sep 9, 2011 | 09:11 AM
95wolv's Avatar
For about 19 bucks at Harbor Frieght or some of your automotive parts stores, you can get a hand vacuum pump brake bleeder with a resivoir, just open the bleed screw, put the hose on, and you can physically pull the brake fluid down to the caliper, then you should be able to bleed it properly, or that may do the job alone, as long as you dont see air bubbles in the drain line to the jar.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
steveo612
Jul 11, 2015 08:35 AM
