polaris 800
Old Sep 17, 2011 | 04:17 PM
kwwiseman's Avatar
Default polaris 800
i have a 2008 ploaris 800 that has losst all electrical power any suggestions
Old Sep 17, 2011 | 05:06 PM
First check that battery has power!Then check the fuses under the front panel,if they are good(use a test light) then check for the 20 amp thermal circuit breaker (on the 800 it should be up the harness strapped on top that goes toward the fuse panel.Check that it has 12 volts in and out. We had several of these that we had to change that shorted out! If the circuit breaker is the problem,just take it to an auto store and match up! Hope this helps! PS Welcome to the forum! OPT
Old Sep 17, 2011 | 07:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. as mentioned, if battery is fully charged and good not corroded connections then check the fues inside the front storage box in the middle under the rubber flap.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
