2003 Warrior 350 Smoking
Old Sep 19, 2011 | 08:14 PM
Pete7072's Avatar
Default 2003 Warrior 350 Smoking
Hey, Had a question about a 2003 Yamaha Warrior 350 I just bought. I bought the bike cheap, and it has a few upgrades ( Jetted aftermarket carb, aftermarket exhaust ). My question is, the guy I bought it from said that it smokes because the engine is runnign rich, and the carb needs to be adjusted. I knew that it had to be more. What are the obvious symtoms... New Piston rings ( assuming nothing is scorched ) and new valve seals? Thanks in advance. Also it's white smoke coming out of the exhaust, and it's pretty much a smoke screen.
Old Sep 19, 2011 | 09:09 PM
JLsparky7's Avatar
White smoke usually indicates coolant....
what does it smell like?
Old Sep 19, 2011 | 09:13 PM
Pete7072's Avatar
I'll let you know tomorrow.... BUT... If it is a coolant smell, wouldn't it point towards a head gasket issue?.... And I believe Warrior's are air cooled
Old Sep 20, 2011 | 09:07 PM
Pete7072's Avatar
There is oil on the exhaust itself.... The smoke is bad only at idle, kind of backs of when you're riding.
Old Oct 1, 2011 | 09:11 PM
91Warrior357's Avatar
Warriors dont have coolant, most likely valve stem seals or something.
Old Oct 1, 2011 | 11:04 PM
Knust's Avatar
White smoke is oil. Check your compression and look for oil in exhaust.
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Hw00d
Sep 10, 2015 08:53 AM
