700 Grizzly ATV
Old Oct 2, 2011 | 12:29 PM
CherylBeattie's Avatar
Default 700 Grizzly ATV
is bogging out. Not stalling just bogging out than runs fine again. Any ideas?
Old Oct 2, 2011 | 05:07 PM
95wolv's Avatar
Well,its fuel injected, so not a jetting problem....lol. I would check the basics, make sure the air filter is clean, you may have a dirty/sticky clutch that causes it to bog at first and then it moves and take the load off the motor, I would start with the filter, then once you are sure the air box is clean and the fuel is good, take a look at the clutch, may need a good cleaning/regreasing,or maybe even a new belt, depending on miles/wear and tear.
Old Oct 5, 2011 | 08:47 AM
kawicowboy's Avatar
Is your reverse light come on when it boggs, I just went through this and it turned out to be the neutral safety switch.
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
