Artic cat 500 4x4 carb leak?
Old Oct 2, 2011 | 02:34 PM
hdwsales's Avatar
Default Artic cat 500 4x4 carb leak?
Hi all
I have a 2000 artic cat with a carb leak. I have replaced the needle, seat and float. Cleaned the rest of the carb and adjusted the float height. As soon as I turn on the fuel the bowl fills up and begins to leak out of the small hole on the inside of the carb throat.
The atv will run at idle but if I try to rev it up it will die.
I have rebuilt many carbs in the past but this one has me stumped, what else should I look for or is it just time for a new carb?
Thanks
Old Oct 2, 2011 | 09:19 PM
ac10's Avatar
Default carb
Originally Posted by hdwsales
Hi all
Thanks
...only thing I could think of is the float setting is wrong,or needle and seat is faulty.blow in to gas line inlet while putting a little pressure on the needle....shoudent have any air passing through.
Old Nov 14, 2011 | 05:35 PM
SHAMROCK4399's Avatar
Hi all
Thanks
Check your choke cable if its stuck,gas will flow out the over flow
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
