noisy 2000 kvf 400
Old Oct 10, 2011 | 04:33 PM
gary webb's Avatar
Default noisy 2000 kvf 400
I HAVE TRIED ALL EXCEPT ENGINE,BUT AT LOW SPEEDS THERE IS A RATTLE LIKE A LOOSE EXHAUST CLAMP.tHE BIKE WORKS GREAT,EXCEPT THIS NOISE ONLY HAS 1900 KMS.THANKS
Old Oct 19, 2011 | 09:55 AM
Hayashi's Avatar
Remove the muffler body and shake it. If it makes a rattling noise, the welded baffle piece inside might have come off.
Old Oct 19, 2011 | 10:32 PM
gary webb's Avatar
Thank you Hayashi
A friend thinks it is the fingers on the centrifugal clutch !! Ever hear of that pronlem?
I will check your ideas meantime
Again thanks
Old Oct 20, 2011 | 09:37 AM
Hayashi's Avatar
Originally Posted by gary webb
Thank you Hayashi
I think your friend has been smoking some real good stuff
Your KVF400 does not have a cetrifugal clutch! Instead, it has a plain CVT system where the drive converter squeezes on the belt as the rpm rises.
Old Oct 22, 2011 | 08:05 PM
gary webb's Avatar
removed & checked the muffler,it was ok,& all fasteners are tight.My mistake friend meant the converter{my mistake}he thinks the fingers that push that converter together may be worn,the bike has only been driven at low speeds
Old Oct 24, 2011 | 03:11 PM
Hayashi's Avatar
The first step is to find out EXACTLY where the noise that you are hearing is coming from, exhaust, cvt, engine?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
