99 beartracker, trouble switching to reverse and back?
Old Oct 15, 2011 | 11:52 AM
Visionist's Avatar
Default 99 beartracker, trouble switching to reverse and back?
I just got a 99 bear tracker and it has trouble going from reverse and back to forward. you have to kind of hold it there for a couple seconds while giving it gas for it to go. What could this be?
Old Oct 18, 2011 | 05:32 PM
apephoto222's Avatar
is it inbetween gears? wont latch in? are you idleing?
Old Oct 18, 2011 | 05:57 PM
Visionist's Avatar
It is from first gear, it makes the sound that it has switched(click) but if you give it gas it just revs the engine and the bike does move. If you hold the handle there while giving it gas it will usually go into reverse.
Old Oct 18, 2011 | 10:25 PM
so lets make sure im on thinking the right way. when you throw it back to reverse is the handle all the way in place where it should be to engage to reverse? Can you feel it engaging? When engaged does it slip out of gear?
Howabout when your normally riding it foward. when downshifting from 2nd gear to first does it shift perfect? or does it slip alittle
Old Oct 18, 2011 | 10:29 PM
Visionist's Avatar
Shifting up and down normally works fine, no grinding or slipping. When I switch to reverse from 1st I can hear it engage, but it will only "work" if I hold it when giving it gas. After holding it for a few seconds it seems to stay. The handle is all the way back for reverse. I have only heard the clutch slip when I was trying to switch from reverse to forward without being fully stopped(didn't realise that I wasn't fully stopped).
Old Oct 18, 2011 | 10:33 PM
im calling it a night Zzzzz. Ill dream about it cause to be honest im not sure how the reverse mechanism works :[ If you havnt yet try looking at a scmatic on yamaha part website
Old Oct 23, 2011 | 03:19 AM
tommy52208's Avatar
There is adjustment in the forward reverse lever somewhere there......I had to do it on my timberwolf and they are basically the same. I had to adjust it a few times before I got it right but if your mechanically minded its not hard at all. Follow the linkage until you see where you have adjustment nuts and you will figure it out.
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
vipers
May 31, 2015 09:12 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
