LT80 help.
the LT80 engine oil is either pre-mixed with or injected into, the fuel. It does not use regular motor oil.LT80 would have had a small oil tank on the side of the engine with a hose leading to a small oil injector pump. I have to assume that your bike is running now, because you want to check the oil and filter.
top of case to the left of the front spocket is the fill plug, on the side near the sprocket is the full line plug, and of course the bottom is the drain
Thanks. I changed it with 10w40 today.
