LT80 help.
Old Nov 2, 2011 | 05:30 PM
Jesse8931's Avatar
Default LT80 help.
Where do I put the tranny fluid and what do i use for it ?
Old Nov 2, 2011 | 07:40 PM
AtvMinibike's Avatar
the LT80 engine oil is either pre-mixed with or injected into, the fuel. It does not use regular motor oil.LT80 would have had a small oil tank on the side of the engine with a hose leading to a small oil injector pump. I have to assume that your bike is running now, because you want to check the oil and filter.
Old Nov 2, 2011 | 07:41 PM
Jesse8931's Avatar
The bike has tranny oil just want to know were to add it and what oil to use.
Old Nov 2, 2011 | 07:43 PM
You see a small tank with a screw on cap on the side of the engine.please use 2 stroke or injector oil.
Old Nov 2, 2011 | 08:05 PM
Jesse8931's Avatar
You dont know what your talking about.
Old Nov 3, 2011 | 07:02 AM
DAMONSQUAD's Avatar
top of case to the left of the front spocket is the fill plug, on the side near the sprocket is the full line plug, and of course the bottom is the drain
Old Nov 3, 2011 | 06:26 PM
So why ask if you know
Old Nov 3, 2011 | 06:41 PM
Jesse8931's Avatar
you were talking about the two stroke oil. I wanted to know about the tranny oil.
Old Nov 3, 2011 | 06:42 PM
Jesse8931's Avatar
Thanks. I changed it with 10w40 today.
Old Nov 3, 2011 | 07:50 PM
irinman2424's Avatar
you put 10-40 in the tranny ??? tranny fluid is not the same as oil
