Front Locker Question
Old Nov 11, 2011 | 01:03 AM
99Kodiak's Avatar
Default Front Locker Question
I was wondering if there is a way to modify my front diff with a locker? I don't want it locked in all the time though... Do they make an after market locker that is engaged by a hand lever like on the newer quads? Or do you guys have any ideas? thanks in advance!
Old Nov 11, 2011 | 06:50 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
most diff locks are electronically engaged- only exception is with the kawasaki brute force, which uses a lever and cable that gives you "variable" degrees of front diff lockup (stupid design imo)
You might be able to adapt another front diff- but you'll probably run into mounting issues and will need access to a welder.
I think some diff locks also use the ecm (like polaris )
I've never seen an "aftermarket" diff locker
warn used to make the 424 disconnect, but all that did was turn full time 4x4 on the honda to 2x4 or 4x4.
maybe someone else knows better than I...
Old Nov 11, 2011 | 07:31 AM
I thought Warn might make something but from what I saw on their website those products are discontinued. Maybe ask your local dealership if there is a diff. that can be swapped in somehow and look for one on eBay if the dealership is too expensive.
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
