honda 70 no spark
Old Nov 15, 2011 | 05:31 PM
barnfullofgoodys's Avatar
Default honda 70 no spark
at wits end .... heres what ive have done so far took flywheel off cleaned replaced stator plate grounded nutral safty switch checked on off switch tested good grounds all good got power to black wire blue wire yellow wire changed cdi box please what did i miss thanks
Old Nov 15, 2011 | 08:36 PM
Oldsman67330's Avatar
did you check the coil? I haven't done it in a long time, so I don't remember the ohms they are supposed to read, but there should be plenty of info on it out there.
Old Nov 16, 2011 | 04:46 PM
Default at wits end
thanks i forgot to add that i also changed coil there is not much left to change!!!!thanks john
Old Nov 27, 2011 | 02:32 PM
dex1710's Avatar
Hi, im having the same sort of thing,with coil signal wire not connected to coil i get 40-60 volts on cranking but as soon as i connect to coil the voltage is very low,if any. Ive have the loom apart today but no joy.if i find the cause ill let you know.maybe its your problem to!!'
Old Mar 9, 2012 | 09:34 PM
Oldtimer's Avatar
Did you check ohms of the stator?
dirt ryder
Sep 27, 2015 09:22 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
CRamshaw777
Jul 18, 2015 05:46 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
